Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
6000
Exterior Light
Turn Signal
Not Working
Turn signals stopped working
1988 PONTIAC 6000
180,000 MILES • 6.0L • 2WD • AUTOMATIC
SUSAN PUGH
MEMBER
1 POST
But my hazard lights are still working. What is the problem? How can I fix this?
Jan 8, 2020 at 9:26 AM
Experienced Mechanic
Hi Susan.
When the turn signals are turned on, does anything happen? For example, do they turn on and not flash or does nothing happen at all?
Also, check to see if the back up lights are working. If they aren't, check the signal/back up light fuse in the fuse box. See pic 1.
Here are a few links you may find helpful:
Image (Click to enlarge)
Jan 8, 2020 at 1:14 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
