If they are working, it sounds like a poor connection in the box. It can be from corrosion, a loose connection, or the fuse box itself may be failing.
If it happens again, perform the same test, but take your time moving/wiggling one fuse at a time to see if there is a specific one that causes it to work. If you do, turn the vehicle off and remove the fuse. Inspect the connectors on the fuse box to make sure they are in good condition, not corroded, and not pushed in too far for the fuse to make good contact.
Let me know if things change or if I can help in any way.
Apr 16, 2022 at 5:57 PM
