Turn signal/tail light
2010 TOYOTA YARIS
95,000 MILES • 1.5L • 4 CYL • 4WD • AUTOMATIC
NFOLAGUE
Driver side turn signal and lower tail light will not work even after bulb replacements and turn signal on dashboard blinks faster.
Sep 21, 2017 at 5:59 PM
MIKE H R
  • 3,094 POSTS
sounds like a ground problem. clean contacts and ground.
Sep 22, 2017 at 2:57 AM
JDL
  • 16,098 POSTS
In the diagram, check voltage and ground. The top wires at lamp assembly, in diagram, are voltage, you can see wire colors. The bottom wire is ground. Use a test light to test.
Did not mean to butt in, I was looking up a wiring diagram.
Sep 22, 2017 at 5:10 AM
