Turn signal switch
1990 CHRYSLER LE BARON
72,000 MILES • 0.7L • FWD • AUTOMATIC
STEECE JUSTIN
So a little while ago my turn signal switch stopped working. it will only turn on the turn signals when I turn on the high beams. So I bought a new one on Ebay that was labeled as tested. I installed it and now the right blinker stays on no matter what when the car is on and the left won't work at all. So I reinstalled the old one and now it only works right half the time. But it is hard finding a turn signal switch for that vesicle so the question is; what should I do to fix this problem? And is there a different turn signal switch I can use from a different car would that be better?
Jan 8, 2017 at 11:06 AM
HMAC300
  • 48,601 POSTS
normally you do not buy used parts for this for the issue you are having. they are $36.00 to $56.00 at rock auto.
Jan 8, 2017 at 10:56 PM
SATURNTECH9
  • 30,869 POSTS
Does your turn signal switch also operate the wipers? also, what is the part number on your old switch?
Jan 8, 2017 at 10:57 PM
