Turn signal short
100,000 MILES • 2.8L • V6 • RWD • MANUAL
ROUGH ROAD
Rear turn signals burn out while vehicle is running. All turn signals work correctly with key on. When engine is started and turn signal is activated, the rear bulbs burn out, the front ones still continue to flash.
May 16, 2017 at 8:47 AM
  • 55,770 POSTS
It sounds like you have a voltage regulator that is out and the alternator is putting to much voltage out, please follow this guide to check the voltage.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
May 19, 2017 at 4:49 AM
