Where is the location of the turn signal relay? Hyper-flashing after installing LED's.
Sep 18, 2023 at 3:23 AM
✓Experienced Mechanic
These cars do not have a turn signal flasher like older cars, it is built into the BCM. You will need to get the LEDs with the built-in resistor to fix the problem.
