Where is the Turn Signal Relay located?
50,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
EJAYE2003
Where is the location of the turn signal relay? Hyper-flashing after installing LED's.
Sep 18, 2023 at 3:23 AM
  • 55,628 POSTS
These cars do not have a turn signal flasher like older cars, it is built into the BCM. You will need to get the LEDs with the built-in resistor to fix the problem.
Sep 18, 2023 at 10:32 AM
