Turn signal problems
170,000 MILES • 2WD • AUTOMATIC
SLWALKER
The left turn signal went out so we put in new 3157A bulb per the manual the signal flashes a fast flash and only shows it is flashing when the headlights are off. Not sure what to do now.
Mar 11, 2018 at 1:54 AM
Good afternoon.
The socket the bulb is in, make sure it is clean of all dirt and debris. this is usually a sign of a bad ground contact in the socket.
Mar 11, 2018 at 3:05 AM
SLWALKER
Thanks we will clean it and see if that helps.
Mar 12, 2018 at 3:29 AM
You are welcome. keep us updated.
Mar 12, 2018 at 3:31 AM
