Turn signal problem
163,000 MILES • 6 CYL
THERELIFETOLIVE HUGHES
My turn signal was blinking when it was not in use and now it completely out. I have replaced the breakers and it still will not come on or make a sound. What do you think the problem was and how do i fix it?
Jun 21, 2016 at 7:23 AM
JOHNNY G.JR
  • 320 POSTS
flashers could be bad, also could be one bad bulb.
Jan 12, 2019 at 10:06 AM
  • 110,248 POSTS
If it doesn't work at all, make sure fuses are good. If they are good, either you have a wiring issue (power supply) or the switch is bad.
