Turn signal problem
TSIGNAL
  • 2005 CHEVROLET EQUINOX
  • 3.6L
  • 6 CYL
  • 86,000 MILES
My truck has been making a continuously clicking sound, coming from the blinkers. I tried to check it but it was not my turn signal being on. I started the truck last night and the actual signal was blinking along with sound without the turn signal being turned.
Friday, March 3rd, 2017 AT 8:52 AM
CARADIODOC
  • 34,104 POSTS
All manufacturers have seen fit to replace the cheap, simple, and reliable thermal flashers with an unnecessarily-complicated electronic flasher, so now we see all kinds of unusual failures. Start by checking that the flasher is seated snugly in its socket. Next, replace it as a test. We normally do not approve of replacing random parts to diagnose a problem, but in this case, the flasher is the likely suspect. The next suspect would be the signal switch assembly, but we also have to consider two wires could be shorted together.
Friday, March 3rd, 2017 AT 4:32 PM
CARADIODOC
  • 34,104 POSTS
Also check that the hazard flasher switch is fully off.
Friday, March 3rd, 2017 AT 4:33 PM
