turn signal lites
88,000 MILES • 3.1L • V6 • FWD • AUTOMATIC
HWCM71
some time they work,then after driving for a little while,then they quite, then when I leave sit while shopping get back start up then they work , just never know when they quite, mech put in new mechnizam, work a while then pulling same old crap again
Jan 14, 2016 at 4:56 AM
PACO8224
  • 117 POSTS
Is it both signal lights messing up?
Jan 14, 2016 at 8:20 AM
HWCM71
yes
Jan 15, 2016 at 12:29 AM
CARADIODOC
  • 34,415 POSTS
The most common cause of intermittent operation is the flasher assembly. The engineers saw fit to replace the ultra-reliable, cheap. thermal flasher that worked fine for many decades with an expensive, unreliable, electronic assembly.
Jan 16, 2016 at 1:44 AM
HWCM71
where is the flasher at and where do i get the flasher/and brand name of flasher, thank you
Jan 17, 2016 at 1:38 AM
HWCM71
Where is the flasher located and where do I the flasher/and brand name of flasher, thanks you
Jan 18, 2016 at 8:04 AM
CARADIODOC
  • 34,415 POSTS
As I recall, the flasher is plugged into the Body Computer which sits above the parking brake pedal assembly. I also remember a flasher mounted above the accelerator pedal but I'm not sure which model that was on. Those by that pedal were known for becoming partially unplugged from their own weight.
Jan 18, 2016 at 9:25 AM
