Hey, I was just wondering if anyone knows how to replace the turn signal lever on the car listed above?
Oct 21, 2024 at 2:34 AM
✓Experienced Mechanic
Sure, here are the instructions on how to replace the turn signal switch lever. I would use a string to attach to the wiring so you can pull the new wiring through using the string you attached to the old wiring before you pull the old wiring through the steering column. Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Oct 21, 2024 at 9:36 AM
WAGONBRO33
MEMBER
Thank you so much. I’ll let you know if this works.
Oct 21, 2024 at 10:05 AM
Our pleasure, let us know how it goes or if you need anymore help.
