Turn signal issues
194,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JON SCHRADER
If you turn turn signal on ,four way switch makes odd vibrating noise but no signals work.
Dec 6, 2017 at 8:21 AM
  • 110,248 POSTS
It sounds like a bad flasher. Take a look at this and let me know if it helps.
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Dec 6, 2017 at 11:40 AM
JON SCHRADER
Changed switch and accessories relay and no help it is actually got more issues now lol. The four way dash lights and fog light switch stay on and they are not on, and now is no turn over just blinks lights.
Dec 6, 2017 at 10:04 PM
JON SCHRADER
Body control module?
Dec 6, 2017 at 10:05 PM
  • 110,248 POSTS
Possibly. However, since things are not turning off, it sounds like maybe a short to power. Check the wiring in and around the fuse block under the hood. Also, if you have not replaced the four way switch, that could be the problem.
Dec 7, 2017 at 10:10 AM
JON SCHRADER
Just wanted to check back to let you know it ended up being my ignition switch smh never would have guessed but smarter minds and equipment got me figured out , thanks for your help though and maybe this will help out someone else when their Impala starts acting up .
Jan 1, 2018 at 8:47 AM
  • 55,758 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Jan 3, 2018 at 12:38 PM
