Turn signal indicators both light up when either signal is selected
167,000 MILES • 3.3L • V6 • FWD • AUTOMATIC
RANGER812572
  • 52 POSTS
On my way across the mountain pass the other day, I turned on my left signal to change lanes. I noticed that my right signal indicator was also blinking (though very dim). The right signal being on also illuminates the left. This is an intermittent issue, and so far my theory was heat under the dash causing some thermal problem. Turned the heat off, no change. The outside lights do not do anything abnormal. If you shut the van off, and start it again, they work fine for a short amount of time. But, the problem is still intermittent. Even smacking the dash does not have an effect on this. Any possible solutions?
Nov 24, 2014 at 5:39 AM
HMAC300
  • 48,601 POSTS
check body to battery ground/engine to body ground/battery to engine ground for corrosion or loose. then check cluster to body ground as well. they are in these areas, LH dash, near LH headlight, near powertrain control module.
Nov 24, 2014 at 7:19 AM
RANGER812572
  • 52 POSTS
Is there a possibility the body control computer is bad? Everything else works fine.
Nov 24, 2014 at 8:12 AM
HMAC300
  • 48,601 POSTS
it could be that or the integrated power module as they go through both. A pro will have to scan it to be sure though. auto parts can't scan for that.
Nov 24, 2014 at 8:15 AM
