According to Dodge, if even one gauge goes out it is not servicable! The entire instrument cluster must be replaced. You can do a self test on it With the key in off possition, press and hold the trip reset button until sof and a number appears in the odometer window then release the button. If a fault code is present, the cluster will display it in the odometer display. Write all numbers that appear. When all codes have been displayed, the cluster will display "end" Post the codes and I will tell you what they mean.
SPONSORED LINKS
Saturday, February 2nd, 2008 AT 4:57 AM
