Where is the turn signal flasher relay switch located?
2012 NISSAN ROGUE
100,000 MILES • 2.3L • 4WD • AUTOMATIC
JOANIET
Turn signals blink rapidly. I need the location of the flasher relay switch.
Apr 5, 2025 at 5:33 AM
  • 55,423 POSTS
So this system does not have a turn signal flasher like older cars, the flashing is handled by the BCM, I would check around the car with the emergency flashers to make sure no bulbs are out and if not let's check the BCM fuses # 1, 3, 9, 10 and 20 in the fuse panel on the left side of the dash.
Here is a guide to help:
This guide may help as well:
https://www.2carpros.com/articles/turn-signals-blink-rapidly
Please go over these guides and get back to us.
Apr 5, 2025 at 8:00 AM
