Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Avalanche
Exterior Light
Turn Signal
Flasher
Location
Where is the Turn Signal Flasher located?
2013 CHEVROLET AVALANCHE
145,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
GREARDON
MEMBER
It sounds like it is in the Under-hood fuse panel, but can't find it.
Apr 11, 2023 at 12:38 AM
Experienced Mechanic
This car does not have a turn signal flasher the turn signal operation is handled by the BCM. What kind of problem are you having?
Apr 11, 2023 at 5:24 AM
GREARDON
MEMBER
Hyper flash from LED Replacements. Interestingly I can hear a relay clicking in proximity to the Under-hood fuse panel.
Apr 11, 2023 at 1:18 PM
You need to get the LED lights with the resistor built in.
Apr 13, 2023 at 3:22 AM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
