Turn signal flasher
26,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SILLYBOY
  • 18 POSTS
Hello, I am trying to locate the turn signal/four way flasher, flasher (relay?). The turn signals stay on steady when the left or right is used. I have looked under the hood and in the access area on the end of the dash board, drivers side.
Should be simple, it is not.
Thanks
Nov 12, 2017 at 6:10 AM
HARRY P
  • 2,292 POSTS
I am trying to dig it up but cannot find anything specific yet. What I have found may not apply, but it says it is in a plastic junction box that would be above the driver's left foot, and above the lower dash kick panel. I will dig some more though to see what I else I can find in a little while. Usually the turn signal flasher is near the hazard flasher, so you can turn the hazards on and follow the click sound. Then look for a similar looking relay in the immediate area.
Nov 12, 2017 at 11:39 AM
SILLYBOY
  • 18 POSTS
I was told that this flasher is for both hazard and turn.
Thanks
Nov 12, 2017 at 7:35 PM
HARRY P
  • 2,292 POSTS
Do the hazards work?
Nov 13, 2017 at 9:11 PM
SILLYBOY
  • 18 POSTS
I thought I answered this...but, I never checked the 4 way hazard lights. And out of the blue, the turn signals started working, and the 4 ways are working. A friend of mine said it might be the turn signal switch.
Don't know what to do with the flasher unit I bought.
Thanks
Nov 28, 2017 at 12:46 AM
HARRY P
  • 2,292 POSTS
No those combination flashers can go like that. They start with intermittent problems, and then completely quit. While it's working, turn it on and follow the clicking sound to the flasher (that's what makes the click sound). Go ahead and order one today if you're getting it online, because it will quit soon.
Nov 28, 2017 at 10:23 AM
SILLYBOY
  • 18 POSTS
Thank You
Nov 29, 2017 at 5:02 AM
  • 55,766 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Dec 2, 2017 at 7:19 AM
