Door chime makes no noise, plus turn signal makes no noise but works?
100,000 MILES • V8 • 4WD • AUTOMATIC
BRANDON SEAGLE
  • 6 POSTS
I tried looking up the location of chime module but no luck. It is a super duty diesel truck.
Jun 16, 2023 at 10:02 AM
  • 110,248 POSTS
The door chime and signal indicator sound is controlled by the instrument cluster. Are you noticing anything other than that failing?
The reason I ask is because I have the diagnostics, but it's about 20 pages long and requires a lot of specialized tooling.
Jun 16, 2023 at 2:08 PM
BRANDON SEAGLE
  • 6 POSTS
I think that is all... it's my boss's truck...he said that's the two main things not working.
Jun 16, 2023 at 10:23 PM
  • 110,248 POSTS
Brandon,
We really need to scan the can-bus to see if there are any codes stored. CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them. Here is a link showing how it's done.
I noticed there are many codes related, so this could potentially point us to the issue.
I also found a test and attached it below. Take a look at it and let me know if you are comfortable performing it.
See pic below.
Jun 17, 2023 at 3:06 PM
BRANDON SEAGLE
  • 6 POSTS
I don't think it is throwing codes but will try on Monday when back at work.... thanks
Jun 17, 2023 at 9:41 PM
  • 110,248 POSTS
Maybe not, but it's worth a try. If you have a chance, let me know what you find.
Jun 18, 2023 at 1:24 PM
BRANDON SEAGLE
  • 6 POSTS
Not throwing codes and fuses are good. Should I just replace instrument cluster?
Jun 22, 2023 at 12:27 AM
BRANDON SEAGLE
  • 6 POSTS
I need answers....I can't go back and forth for days and days.
Jun 22, 2023 at 12:28 AM
  • 55,694 POSTS
The chime is produced through the radio speakers, can I ask if the radio is working? Also have you checked all fuses with the system on, this guide can help.
If the radio works and the fuses are good it sounds like the SJB (smart junction box) is going out but to be sure let's do a CAN scan, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the SJB out, check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 23, 2023 at 3:27 AM
BRANDON SEAGLE
  • 6 POSTS
Yeah, it was the instrument cluster like I said so thanks for nothing... all you did was try to get me to spend money on useless stuff. I diagnosed it myself.
Jun 23, 2023 at 12:52 PM
  • 110,248 POSTS
Brandon,
The cluster is where I started but didn't want to suggest replacing it until I had confirmation it was bad. I'm sorry you feel the way you do. Trust me when I say, I wasn't trying to get you to spend money. It is quite the opposite. Also, I realize you needed answers quicker, but please understand, I work two jobs and do this at night to help people. I'm not getting rich.
Regardless, I'm glad to know you got it figured out and it's working.
Jun 23, 2023 at 1:48 PM
