Turn signal conversion from incandescent to led
95,000 MILES
BRIAN DIGIOVANNI
Hi, I am converting my front left turn signal from incandescent bulbs to led using a resistor. The three wires on the wiring harness are a brown with a stripe, and a white wire and green wire. The resistor has a black and red wire. What color do I connect my hot wire on my resistor to on my wire harness and what color do I connect my black wire on my resistor to on my wire harness? so that i can hook up my resistor so my LED's flash correctly. Thank you. Brian.
Oct 27, 2016 at 4:13 AM
  • 55,851 POSTS
This is hard to say, does the instructions in the kit let you know? Here is a wiring diagram to help you.
Let me know if you need more diagrams
Best, Ken
Oct 31, 2016 at 3:24 PM
BRIAN DIGIOVANNI
Thanks this will help
Oct 31, 2016 at 9:37 PM
  • 55,851 POSTS
Please let us know what you find so it will help others.
Best, Ken
Nov 1, 2016 at 2:47 AM
