Turn signal assembly
200,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
GELVINN
For some reason, my turn signals will not work. I have checked the hazard lights and they work. I have replaced the turn signal switch inside the steering column, replaced the turn signal/hazard flasher (looks like it is only one unit combined), and replaced the fuse inside the fuse box. I inspected all turn signal/hazard light bulbs and all are good. I do have a new 30 amp circuit breaker installed also in the fuse box. and yet the turn signals still are not working. Any ideas?
Jul 25, 2017 at 2:19 AM
HMAC300
  • 48,601 POSTS
there is a turn signal relay on right side of steering column support for just turn signals. fuse 6 is for turn signals. See pictures for turn signal relay etc.
Jul 25, 2017 at 5:16 AM
GELVINN
Is the relay on the same piece as the break light, which is attached to the break pad stem? or is it behind the dash?
Jul 25, 2017 at 5:26 AM
HMAC300
  • 48,601 POSTS
it's under the dash on the steering column support which is a steel plate holding column in
Jul 25, 2017 at 9:23 AM
