Turn signal and hazard lights stopped working?
2004 CHRYSLER CONCORDE
147,523 MILES • 2.7L • V6
NEWCARGUY
Recently my flasher on my turn signal and hazard lights were going out, so I switched it. Now the new one burnt up and it's been 3 days since I got it. What else can I try to figure out what the issue is? The fuse is good, the bulbs are good.
Aug 13, 2022 at 9:28 AM
  • 110,244 POSTS
What is actually happening at this point? For example, do the signals or flashers work at all? Do they turn on but not flash? Let me know.
Also, let me know if it was the multi-function switch that you replaced and if the flasher has been replaced. What indicates it has burned up? Is it a fuse issue, the wiring at the switch, or what?
Aug 14, 2022 at 1:17 PM
