Turn signal and hazard light not working
250,435 MILES • 4 CYL • 2WD • MANUAL
RICHARD NEGRON BURGOS
The turn signal lights and the hazard light don't work. I have change the multi switch and change fuse, but it still nothing.
May 26, 2021 at 7:47 AM
  • 55,649 POSTS
We need to check for power at the fuses to make sure they are good (the fuses are in the diagrams below). here is a guide to help you and the fuse location as well. Also I have included the turn signal wiring diagrams so you can see how the system works.
May 28, 2021 at 3:07 AM
I did check for power and it does have power going to the fuse.
May 28, 2021 at 3:16 AM
  • 55,649 POSTS
Okay, let's check the TNS relay which in under the hood inside the fuse panel. here is a guide you help you test it. You you are in question try replacing it.
May 30, 2021 at 4:39 AM
