Turn signal lever and brake lights not working
1998 CHEVROLET MONTE CARLO
207,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
JEUBANK1
Brake lights stop working and turn signal lever won't go up or down.
Feb 17, 2020 at 5:18 AM
JOETECHPRO
  • 705 POSTS
Hey JEUBANK1,
If the turn signal lever will not move then you have a faulty signal lever and it will need replacing.
The signal to the brake lights goes through this switch so it may be causing both of your issues.
Please see the wiring diagram attached.
I have also included the instruction for replacing the turn signal switch.
Regards, Joe
Feb 17, 2020 at 6:01 AM
JEUBANK1
Thanks Joe.
Feb 18, 2020 at 12:08 AM
JOETECHPRO
  • 705 POSTS
Hey JEUBANK1,
No problem at all.
Keep us updated on your progress with this issue.
Regards, Joe
Feb 18, 2020 at 12:31 PM
