turn signal and brake lights
1999 PONTIAC SUNFIRE
195,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRISSYLYN
The driver side turn signals and brake lights don't work but the passenger side does. Changed the bulbs and installed a new turn signal switch
Jan 23, 2016 at 11:09 AM
HMAC300
  • 48,601 POSTS
check the yellow wire to see if any power is coming through it from t/s switch if not it may be a bad flasher which is hazard switch. alos check ground at taillight and parking light in front.
Jan 24, 2016 at 12:35 AM
