Turn signal will not cancel when turning left
80,000 MILES • V8 • 2WD • AUTOMATIC
DAVE2167
I can here a click and it cancels when turning right. I was thinking of trying to replace the multi switch assembly. Part number Motorcraft 4W4Z13K359BA. It looks like I wouldn't have to pull the wheel because it's a 2003 - 2006. It looks like the early LS 2000 - 2002 had a different assembly. I know or think there is a cam and if it is bad then the wheel would have to be pulled but as I said it works one way and I can hear a click. Something doesn't feel right in the assembly even when switching on the brights. it's kinds stiff. something just doesn't seem right with the turn signal arm.
Jul 20, 2019 at 11:37 AM
BMDOUBLE
  • 1,139 POSTS
I have replaced many of those switches on Lincoln LS, the cancel tab dislodges from the spring and only will affect one side.
Jul 20, 2019 at 1:27 PM
DAVE2167
Thanks for the reply, so am I thinking right about just replacing the arm assembly?
Jul 20, 2019 at 1:36 PM
BMDOUBLE
  • 1,139 POSTS
If it has mechanically failed, yes.
Jul 21, 2019 at 1:16 AM
