turn signal
120,000 MILES • V8 • 2WD • AUTOMATIC
LEMAGOO
left turn signal and brake light works, right turn signal and brake light doesn't work. All the front lights work. Inside truck on the dash the right turn signal arrow blinked faster than the left so I changed the flasher. That made the left and right arrows blink at the same speed but the right turn signal and brake light still doesn't work. I changed bulbs, flasher, and have visually checked the fuse, the fuse looks good. But my right turn signal and brake light still doesn't work, any suggestions.
Jan 29, 2016 at 4:48 AM
WRENCHTECH
  • 20,761 POSTS
The first thing you need to do is get a test light and start testing the wire and socket to see where you have power and where you don't. Then you can systematically track down the problem.
Jan 29, 2016 at 5:32 AM
