Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Acclaim
Exterior Light
Turn Signal
Flasher
Turn signal
1994 PLYMOUTH ACCLAIM
56,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
ROGER ALFORD
MEMBER
The turn signals and the four-way flashers are not working. I have checked the fuse it is good.
Jul 21, 2017 at 7:37 AM
HMAC300
Experienced Mechanic
check the flashers both may be bad. if both work then it may be the multi function switch. See picture.
Image (Click to enlarge)
Jul 21, 2017 at 8:55 AM
ROGER ALFORD
MEMBER
Jul 21, 2017 at 9:18 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine has low power
