Turn signal
140,000 MILES
ICANTO
2003 Acura MDX, right rear turn signal does not work. Have changed bulb, and still does not work. Right front turn signal works. On the dash, I have a rapid blinking light.
Please help.
Changed bulb to the left side and it works perfectly, Hazards works fine, but not on the right rear.
May 19, 2013 at 5:25 AM
check for power to the socket with a test light. it may be a failed socket assembly
May 19, 2013 at 10:11 AM
HONDATECH1983
  • 109 POSTS
Check the socket for corrosion and anything of the sort that may be preventing a good connection.
Nov 19, 2013 at 9:47 AM
