Turn signal wiring diagram or schematic?
200,000 MILES • 4WD • AUTOMATIC
DOLLABILL25
  • 49 POSTS
I would just like the wiring diagram or schematic for a 1996 Toyota Tacoma please if you could help me out with that I would be very appreciative thank you
Nov 14, 2026 at 4:04 PM
DOLLABILL25
  • 49 POSTS
I'm sorry I forgot to tell you what wiring diagram or schematic I would like it is for the turn signals please thank you
Nov 14, 2026 at 4:05 PM
STEVE W.
  • 15,418 POSTS
These are the OE and aftermarket diagrams for the turn signals and markers. What is the issue you are seeing? There are a number of interconnects that can give you shortcut tests. Some might help.
Nov 14, 2026 at 8:07 PM
DOLLABILL25
  • 49 POSTS
Well I don't have blinkers at all nor do I have hazard lights when I hit my hazard button or when I use my blinker switch there's no clicking no flashing nothing nothing at all and I've checked all my fuses and all that I don't know what's wrong
Nov 14, 2026 at 8:35 PM
STEVE W.
  • 15,418 POSTS
OK no signals and no flashers means it's a shared component, The most likely one is the flasher. It is shared by both but gets power from 2 different fuses depending on which function you select, in turn mode it gets power through the turn fuse and sends the power over to the flasher which is then selected through the multifunction switch. Then if you select the hazards another part of the hazard switch gets power through the horn fuse and sends it to the other section of the flasher so it can flash the lights through a different circuit. As such it is most likely a bad flasher or the socket it is in. The unit is Toyota #81980-AA021 or #81980-AC030 Depending on build date. The best way to tell is to go the the junction box in the left kick panel, remove the bolts and pull it out enough to get to the flasher and get the number off it. Look over the connectors in there as well, I have seen some melted ones if the truck was used to pull a trailer using the wrong wiring harness.
Nov 16, 2026 at 6:01 AM
