Turn signal fuse number and location
164,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
KIM BROOKS
Need to know what number fuse is for turn signals, no manufacturing manual available. Also, where would the turn signals fuses be under dashboard or under hood?
Feb 22, 2019 at 9:19 AM
SCGRANTURISMO
  • 4,897 POSTS
It is in the fuse relay panel under the left side of the dash, fuse#18(5A). I have included a diagram for you in the diagrams below.
Thanks,
Alex
2CarPros
Feb 22, 2019 at 10:39 AM
BMDOUBLE
  • 1,139 POSTS
Make sure there isn’t signs of water intrusion, windshield leaks on these trucks are extremely common i.e. rust on the metal around the fuse panel.
Feb 23, 2019 at 12:39 AM
KIM BROOKS
Thank you BMDOUBLE. Yes, I did see rust on panel door.
Thankfully once I found the fuse and diagram of panel, a new fuse finally.
Feb 23, 2019 at 9:55 PM
