Turn signal
2005 GMC YUKON
100,000 MILES • V8 • 4WD • AUTOMATIC
KATHY HINTZ
The turn signals blink when turned on, but stop when i step on the brake. What is wrong?
Aug 1, 2017 at 12:25 AM
CARADIODOC
  • 34,366 POSTS
Incorrect lamp operation is almost always caused by a bad ground wire. On older vehicles, inspecting the wire harness and where the ground wire bolts to the body usually reveals the break. On newer vehicles, many of them use circuit boards or flexible film circuits that cause a lot of trouble. The clue is only one side is affected, and all the functions on the other side work properly.
Aug 1, 2017 at 11:40 AM
