After replacing hazard flashing light the turn signals flash fast
130,000 MILES • V6 • 2WD • AUTOMATIC
TVALDES66
I just installed a new hazard flashing light after I installed it my turn signals flash really fast.
Jun 14, 2021 at 6:06 AM
Here is a guide that will help with covering the basics on this issue:
https://www.2carpros.com/articles/turn-signals-blink-rapidly
However, the fact that you just replaced a bulb, is there a chance this is an LED bulb? If it is then the resistance is different of the LED light then the halogen bulb and so it throws off the timing of the light and it flashes fast.
Can you get a picture of the packaging from the bulb and that will help us determine if this is the issue? Thanks
Jun 15, 2021 at 11:30 AM
