i have no rear air, hot or cold, turn switches on front and back and have nothing. i check the blower motor and it work's fine. now i am at a loss.
Sep 28, 2016 at 6:06 AM
BIGBLUE196
MEMBER
Front A/C and heat work fine.
Sep 28, 2016 at 6:07 AM
WRENCHTECH
✓Experienced Mechanic
Here is the wiring diagram for the rear blower. Start out by testing the fuses in the diagram and then test at the motor to determine whether it is power or ground that you are missing at the plug.
