Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
CRV
Exterior Light
Turn Signal
Not Working
Turn signal lights not blinking in panel
2003 HONDA CRV
175,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOHNCH2010
MEMBER
My turn lights / flashing are not blinking in the panel, but they are working fine in front and rear the car.
Sep 12, 2020 at 2:32 PM
Experienced Mechanic
If they both stopped at the same time, but the outside ones are working, chances are we lost the ground to the ones on the instrument cluster.
There is a black wire that is under the right side of the dash. It will be mounted with others. See pic 2
Images (Click to enlarge)
Sep 13, 2020 at 12:04 PM
JOHNCH2010
MEMBER
Sep 14, 2020 at 12:09 AM
You are very welcome. Let me know if you get it fixed or if you have other questions.
Sep 14, 2020 at 11:37 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
