Turn/hazards brake lights
171,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
TRAY55
My car's turn/hazards or brake lights do not work the third one does. Replaced multi-function switch I was told that did not fix the problem. what else can it be ?
Nov 21, 2017 at 1:33 AM
  • 110,251 POSTS
GM has had issues with the hazard light switch. Try this, wiggle the hazard light switch and move it in and out to see if it changes anything. Let me know.
Nov 21, 2017 at 11:29 AM
TRAY55
Will do!
Nov 21, 2017 at 12:05 PM
TRAY55
Same thing nothing changed. When I tried that.
I tried wiggling and pressing in the hard switch nothing changed. Any suggestions?
Nov 23, 2017 at 4:44 AM
  • 110,251 POSTS
Not sure, but are you the one having the problem with the signals and brake lights? Is that what the problem is? I replied to a different thread the other day, and I am not sure if you are the same person. If not, please let me know what the problem is you are dealing with.
Nov 24, 2017 at 2:16 AM (Merged)
TRAY55
Yes it is the same person.
