When accelerating there is a rush of air coming from the right side of the engine
96,000 MILES • 1.5L • 6 CYL • TURBO • 2WD • AUTOMATIC
JESSICA CAMPBELL2
  • 5 POSTS
Just replaced the throttle body. When I accelerate, I hear a rush of air coming from the right side of the engine. it doesn't do it when cruising at a set speed. Cars idle is slightly off as well, but no relearn was done with battery after replacing throttle body. The vacuum line appears to be fine as well. When the throttle body was replaced, the mechanic said it had more oil in it than it should have. My Eco boost also has not worked in months, but I did not care for it anyway so as long as it wasn't a problem, I let it be. The air rushing sound seems to be worse between 40 and 45 MPH. My brakes are fine as well, no change in them, and I have no codes either.
Feb 4, 2022 at 11:47 PM
  • 110,248 POSTS
Is the check engine light staying on when the engine is running? As far as the noise is concerned, when you are accelerating, the throttle plate opens, and a lot of air enters the engine via the throttle body.
Also, the charge air tube for the turbo may be leaking. That would explain why it isn't working.
Do me a favor. If you look at the attached pic below, I circled three things. Number 1 (circled in blue) is the charge air tube for the turbo. Do the best you can to see if anything is cracked, damaged, or disconnected.
Numbers 2 and 3 (circled in red and black) are the air tubes from the air filter. Make sure they weren't left disconnected.
If possible, have a helper throttle the vehicle on and off quickly while you listen to the engine with the hood open. See if you hear the sound.
See pic below.
Feb 5, 2022 at 10:30 AM
JESSICA CAMPBELL2
  • 5 POSTS
Hi Joe, no there are no lights or codes, which is why I was thinking that something may not have been put on tight enough as well. Thank you for your response! I will definitely check out the things you circled in the diagram.
Feb 5, 2022 at 10:30 PM
JESSICA CAMPBELL2
  • 5 POSTS
I tried what you suggested and found nothing loose or cracked. The helper I had noticed vacuum when taking oil filler cap off, so he suggested a manifold gasket? Does this sound plausible?
Feb 6, 2022 at 6:21 AM
  • 110,248 POSTS
Jessica,
When you say a vacuum, that shouldn't be and wouldn't be a manifold gasket. Is it possible for you to record the sound and upload it for me to hear?
Feb 6, 2022 at 12:36 PM
JESSICA CAMPBELL2
  • 5 POSTS
I can try to record it and he just put his hand over where you fill the oil up with the cap off and car running and said it had too much suction.. i read that some suction is normal though....
Feb 6, 2022 at 12:49 PM
  • 110,248 POSTS
When it's running, you want a vacuum. The vehicle has a PCV system (positive crankcase ventilation). The purpose is to remove crank case pressure. If the engine is running and you feel a vacuum, it's normal.
Let me know if you can get the audio. Hopefully, it will help me.
Feb 6, 2022 at 1:16 PM
