starts but turbo wont kick in
126,000 MILES • 1.3L • 4 CYL • TURBO • MANUAL
BEV BROWN
  • 6 POSTS
Endless starting issues; starts but turbo will not kick in. I tried checking all valves and vacuum solenoid. The only way I can get it to start is by removing vacuum pipe from turbo. checked throttle body valve. also smoke when revving. done pedal test actuator sticking.
Oct 4, 2016 at 5:37 AM
  • 55,770 POSTS
Hello Bev,
This is a classic case of the turbo being worn out. Remove the turbo to see if the impeller is loose in the housing showing you the bearings are worn out. This is a common problem.
Please let us know what you find so it will help others.
Best, Ken
Oct 7, 2016 at 5:25 AM
