oil leaked out of the dipstick
178,000 MILES • 2.3L • 4 CYL • TURBO • AWD • MANUAL
TIM ROY
First it leaked oil from blow off then it would stall on startup if i did not give it a bit of gas. then pflow leaked oil then lack of boost stated and back fired once. so i did a test with pflow off to see if it was a lack of air boosted only 13 psi. when it should be at least 18 and oil leaked out of the dipstick.
Feb 6, 2017 at 9:16 PM
HMAC300
  • 48,601 POSTS
if you are getting oil out of dipstick it may be pressurizing the engine too much. Check for a bad seal on turbo and the PCV system. 13 psi is a lot of boost so check compression as well.
Feb 6, 2017 at 10:09 PM
