Turbo boosting late at 3,000 RPMs and black smoke coming from the exhaust
2008 VOLKSWAGEN GOLF
138,000 MILES • 2.0L • TURBO • 2WD • MANUAL
VWGOLF08
Recently I put in a new hybrid turbo and engine after the old turbo broke after a remap. Not the new turbo boosts late at around 3000 rpm and there is a lot of black smoke from the exhaust when the turbo spools/boosts.
The actuator and MAF sensor seem fine what else could be the issue. Could it simply need a remap once again?
Jun 26, 2022 at 10:24 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,193 POSTS
It sounds like the new turbo is bad, can you check the turbine endplay to confirm? This guide can help:
https://www.2carpros.com/articles/how-turbo-chargers-work
Are there any codes in the car, please follow this guide as well?
Jun 27, 2022 at 9:33 AM
VWGOLF08
The turbo just got put in recently and we've had a look at it and there's no issues with it at all. Also, it's not throwing up any codes either. Struggling to understand what the issue could be.
Jun 27, 2022 at 10:30 AM
  • 54,193 POSTS
How did the engine run before the last turbo went bad? Does the engine have good vacuum at idle? Is the new turbo stock? If not, you may need to remap it. I would remove the spark plugs to see what they look like. You can upload the pictures in your response.
Jun 28, 2022 at 10:58 AM
VWGOLF08
The original engine ran away when installing the new turbo. I've got another engine in now, it's a diesel car so, doesn't have spark plugs. I just checked and tried another vacuum solenoid box on the car, but it's made no difference...
Jun 30, 2022 at 7:04 PM
  • 54,193 POSTS
Let's run the codes to see what comes up. Here is a guide to help:
Jul 1, 2022 at 10:10 AM
VWGOLF08
It's come up with a P0299 turbo charger under boost code.
Jul 1, 2022 at 8:53 PM
  • 54,193 POSTS
It seems like everything is pointing to a bad turbo or you have a clogged exhaust system, try to undo the exhaust at a point so it can flow freely and see what happens.
Jul 2, 2022 at 2:50 PM
