Code 0299, where is the Turbo Boost located?
2019 GMC TERRAIN
105,150 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
CAMBIZI
Where is the turbo boost location? I have code 0299. I would like to check if maybe there is a leak on the turbo oil line feed? Thanks
Aug 22, 2023 at 2:53 PM
  • 110,240 POSTS
As far as the code, it is specific to turbo under boost. If you look at the first three pics below, they provide the circuit testing diagnostics. The remaining pictures (to the best of my ability) should be all related hoses.
Take a look through the pics and let me know if they help.
See pics below. The pics show parts and are headed with the hose or component name. I had to jump through multiple sections to get them. I hope I got all that you need.
Aug 23, 2023 at 2:20 PM
CAMBIZI
Thank you! I will check this out. I appreciate the quick response.
Aug 29, 2023 at 2:08 AM
  • 110,240 POSTS
No problem whatsoever. Let me know what you find or if I can help in any way.
Aug 29, 2023 at 11:04 AM
