Sure. If you look on Ebay or Amazon they might even have kits already put together for your vehicle. The one piece of advice that I would give you from experience, is that if you want to put a turbo on an engine, make sure that that engine is healthy and fairly new. If you put it on a high mileage or tireder engine, the engine will not be able to handle the turbo and you will do catastrophic engine damage to your vehicle. I would not recommend putting a turbo on your vehicle because of it's high mileage.
Thanks.
Alex
2CarPros
Apr 30, 2019 at 2:21 AM
