turbine sensor
1999 HONDA CRV
200,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
BAJUS
  • 5 POSTS
Please where is the turbine speed sensor located on the gear box on my car? If possible could you send the picture of the turbine speed sensor?
Thanks.
Theo Bajus
May 20, 2016 at 6:59 PM
WRENCHTECH
  • 20,761 POSTS
Honda does not use the term "turbine" sensor, but the main-shaft speed sensor is the one that does that job. This video will show you how to replace it https://youtu.be/f3bETtCIdxM https://www.2carpros.com/images/external/86164145.jpg.gif
May 20, 2016 at 11:06 PM
BAJUS
  • 5 POSTS
Thanks very much. I will replace it and get back to you.
Thanks once more.
May 21, 2016 at 1:05 AM
