I replaced the plugs and wires and now the car is not running right
141,256 MILES • 3.4L • AUTOMATIC
CYNTHIA MALLORY
Changed plugs and wires now car will not run right. could the suggested firing order be wrong ? If not what could be the problem?
May 10, 2020 at 1:39 AM
Good morning,
Yes, check the firing order.
I attached a picture for you to test the firing order.
Make sure the wires to to the correct cylinder with the numbers on the picture.
May 10, 2020 at 1:50 AM
