trying to see which is the problem
115,153 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
ALLISONRON
There was milky stuff in my oil..my water in my radiator is fine,water stay in it and it been five months since I had put water in it because it still at the hlaf mark in the jug..any tips of what to look to so I can fix it
Dec 9, 2015 at 11:25 PM
JOHNNYT73
  • 924 POSTS
IF the oil in the crankcase when looking on your dipstick is milky then you most likely have headgasket leak. The coolant in your reservoir bottle is not a representation of what is actually how much coolant is in the engine. You need to remove the radiator/pressure cap to check you coolant level.
Dec 10, 2015 at 1:28 AM
