Where is the oil pressure switch located?
216,673 MILES • 2.5L • 2WD • AUTOMATIC
RAC1306
I’m trying to locate the oil pressure switch on my vehicle listed above. My oil pressure light comes on every now and again. I have just had an oil and filter change, and it still comes on after. I think it could be a faulty switch, and I need to replace it. Just don't know where to locate it.
Apr 25, 2025 at 11:32 PM
MECHTRIX
  • 595 POSTS
On the VW golf, I believe the oil pressure switch is located on the oil cooler might be hiding a bit once you locate it ", follow the wires that should lead you to it. good luck
Apr 27, 2025 at 7:15 AM
RAC1306
Is there a diagram available anywhere? Is this a under the car or under the hood location?
Apr 27, 2025 at 7:39 AM
MECHTRIX
  • 595 POSTS
its been a while but I believe its strait above maybe a few inches up from the oil filter /cooler, on the driver's side front of the engine. got to take off the plastic gravel guard under the car look up from there and you should see it with a good light.
Apr 27, 2025 at 8:10 AM
