trying to locate shift detent spring
1991 MITSUBISHI GALANT
200,000 MILES
TELECASTER77
My car pops out of 4th gear while driving. My manual says to replace shift shaft detent spring. Where is the shift detent spring located on.................................................................................
Aug 14, 2013 at 7:12 AM
KHLOW2008
  • 41,814 POSTS
I don't think that is a shaft shaft detent spring problem. Symptoms indicates a bad synchroniser ring.
Shift detent spring is behind the locking blot at side of transmission. There would be 3 bolts in a line near to each other somewhere near the shift level on transmission housing. The center one would be for the shift fork,
Aug 14, 2013 at 2:22 PM
