Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Fuel System
fuel pressure
trying to locate fuel pressure switch
1998 TOYOTA CAMRY
200,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEBULLOCK9
MEMBER
1 POST
runs rough for a while then smooths out
Mar 16, 2015 at 3:51 AM
HMAC300
Experienced Mechanic
scan for codes, check fuel pressure with a gauge auto parts rent it. then check for a vacuum leak like hoses cracked /broken.
Mar 16, 2015 at 5:11 AM
HMAC300
if you mean air/fuel ratio sensor it's in exhaust pipe one per side.
Mar 16, 2015 at 5:13 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
