No crank or start after sitting for two years?
61,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
AZDANNO04
  • 378 POSTS
Put a rear outer tire on and new battery. When turning the key. No crank nor clicking. Turned on the lights, just the running lights. No low beams or high beams. Could it be the starter? It did start and run but that was two years. Trying to get it out of the storage yard and clean it up to sell.
Jul 18, 2024 at 10:46 PM
  • 55,746 POSTS
Yes, it could be the starter, but I would check the main power leads coming off of the battery it sounds like one of them is corroded. Also check the fuses as well. To check if the problem is the starter, I would use a test light when the key is in the crank position to see if there is power. Here is a guide to help and the starter wiring diagrams so you can see how the system works.
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Jul 19, 2024 at 5:22 AM
AZDANNO04
  • 378 POSTS
Do you have a layout or diagram of the fuses?
Jul 19, 2024 at 11:14 AM
AZDANNO04
  • 378 POSTS
Also need to drop the fuel tanks to clean or have them replaced?
Jul 19, 2024 at 11:22 AM
AZDANNO04
  • 378 POSTS
What type of antifreeze do I use?
Jul 19, 2024 at 11:23 AM
  • 55,746 POSTS
Sorry we don't have the fuse layout; I would drop the tanks and flush them out and let them dry completely. You can use any kind of antifreeze you want, prestone is good stuff.
Jul 20, 2024 at 3:04 AM
