Engine shuts off
152,000 MILES • 5.7L • V6 • TURBO • AUTOMATIC
JEVON0142
It is a 300c with the hemi. It cuts off after it’s been running for a while and at the red lights. I have replace the front control module, a new alternator, new battery and it still doing the same thing.
Apr 16, 2021 at 2:34 PM
  • 110,248 POSTS
When it stalls, does it start right back up? I'm asking because a failing crankshaft position sensor can cause this to happen. Oftentimes, they are affected by heat. When they get hot enough, they fail. Most times, they need to cool for a bit before the car will restart. Interestingly, it may or may not set a check engine light.
Do me a favor. Read through this link and let me know if it seems to mirror what you experience.
If it had a delayed start after it stalls, check to see if there is spark to the plugs. If there isn't, chances are it is the crankshaft position sensor.
If you determine it is bad, here is a link that shows in general how one is replaced:
The attachments below are the directions and pics specific to your vehicle for replacing the sensor. Note: The Crankshaft Position (CKP) sensor is located at the right-rear side of the engine cylinder block.
Let me know if this helps. Also, let me know if the check engine light is staying on when the engine is running.
Apr 16, 2021 at 3:38 PM
JEVON0142
Hello, tried what you said did not work, car still cuts off. Took it to another shop he said it is one of the modules that is heating up and sharing the car off, but it’s not giving a code telling which one. Any ideas on which one it could be? because that it’s going to be very costly to try and replace all of them. Thanking you in advance.
May 6, 2021 at 1:54 AM
  • 110,248 POSTS
It could be a few different ones. He didn't mention which one it is? Also, did you replace the crankshaft sensor?
By chance, did he give you a list of modules he wants to replace? At least I can tell you if they could be possibilities.
Without a code, it is a guessing game for me as well. I hope you understand.
May 6, 2021 at 12:46 PM
